Metalhead
I've got a new intermittent vacuum leak somewhere on the auto hubs system. I say intermittent, because on some days the system works perfectly on demand. On others, the AC system switches over to blowing through the defrost vents after 10-15 seconds, and I verified the hubs were not engaged by spinning the u-joints by hand.
I've already replaced a hub seal at the right front that I verified as bad. After that repair, the system worked perfectly for about 2 months until now.
It doesn't seem that I have another bad hub seal, since the system still engages perfectly on demand on some days, but maybe you all might have some thoughts on that...
How about the vacuum solenoid at the dash? Is there a way that I can test it? Maybe it's bad, letting a big leak happen on some days, not on others.
Thanks in advance...
BTW, I see the other thread going on this right now that's similar, I'm keeping a watch on that for this problem as well...
