Vacuum hubs
Potentialbuyer
Cazenovia/NY
Can the vacuum hubs be disassembled and cleaned? I am going to put some ball joints in my 2000 F350 and I wanted to go through the hubs too. The vacuum hubs used to work OK when I purchased the truck two years ago but they don't work now. I am going to replace the o-rings and seals for the wheel bearings and locking hubs too. Is the special tool from Ford necessary to install the knuckle seal on the axle shaft?
Thanks in advance
rammertide07
Rogersvilles, AL
I've seen step-by-step pics somewhere on here, but I can't remember where. I was told though that if you lock them in every now and then they will stay in pretty good shape.
FlorWhitfe
