up s*** creek...
Norcal250
Gimp member
Castro Valley, CA
No instrument panel, no overhead console, no power windows, no dome lights, starts and runs, but after I put it in gear the idle kicks up and it doesnt want to move, like the parking brake is on (and no the parking brake is not on)... all fuses good.... got code U0155 (Lost Communication With Instrument Panel Cluster (IPC) Control Module) anyone have any ideas before I call the dealer???:dunno
I should probably keep my mouth shut since I know nothing about a E350 but the trucks have two fuse panels(one under the dash, one under the hood). If the E350 does have two did you check them both? Check the relays too...
Norcal250
Gimp member
Castro Valley, CA
Yes there is two on the vans... and i checked both... relays are good too...
My only other thought would be with all the stereo equipment you have in your signature could something in the dash came unplugged?(Lost Communication With Instrument Panel Cluster). Just shooting in the dark here :dunno
Norcal250
Gimp member
Castro Valley, CA
well everything looks ok under the dash as far as I and two of my friends can see... i'm just gonna have it towed to the dealer and have them fix it... I'm more worried about the possible transmission or ecm failure... I just tried to drive it and when I gave her some throttle it just seemed like it was out of fuel...
Unless you have drove over 100K I am thinking a 2005 should be under warranty so I think having the dealer fix it would be your best bet. Sorry I wasn't any help. :sorry
Norcal250
Gimp member
Castro Valley, CA
no apology needed bud... thanks for helpin out:sweet
it only has 13K miles on it, so she was loaded onto a flatbed towtruck a while ago and was taken to the dealer... the freightliners front tires were about 6 inches off the ground for a second while leveling the bed out with the van on it... that was pretty cool...
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I had some problems once with some similar symptoms. It turned out to be corroded battery posts. I took the cables off, cleaned them good with a wire brush and a bottle of Coke (emergency, 500 miles from home repair methods :eek: ), and all was well again.
haulin8or
Hotlanta, GA
I agree with Tail_Gunner, when my alternator went out I had some pretty crazy things happening when the batterys started losing charge. Entire dashboard went out, climate control system, stereo and the ABS light would come on. :2c
Norcal250
Gimp member
Castro Valley, CA
thanks for the tips guys.. I got a voicemail today from the service advisor here at my local steal-ership... and I'll be sure to post the bad news on here tomorrow after I call him back...
Ricksofla
