Unusual Front End (Axle) Noise
So between the seals/u-joints and the ball joints, I have cured all the noise in the front......
Just wonder now if what I was having happen was a "mini death wobble" since the ball joints were loose, and I caught it before I had a MAJOR issue......
you bet your sweet bippy you did..
the buzzing noise was likely the lockout parts of the hub rubbing on each other after the bump had slammed the axle around
Pm_guru
