Hi Guys,
I'm new here so this may have been posted alot of times so I'm sorry if it's a old subject.
I have a 04 SD F-350 dually w/6.0 diesel. I was about 20 miles out of Kingman, AZ. on my home to Colorado when I started to get some blue smoke so I pulled over and it stopped smoking. A mile or 2 down the road I started getting black smoke and by the time I got to the Ford dealer in Kingman it was just fogging the whole block. The service manager said it was pry a injector problem. They ran a computer check on it and said that I had 3 cylinders with low compression. They said they would have to tear down the motor to know forsure what was going on. They also said that since I had a hypertect module and after market air breather on it that ford my turn me down as far as warranty work goes. I said I had bought this from a Ford dealer in Denver with this stuff on it and I wasn't told that it would void my warranty. I said I needed the truck so find the problem and I rented a car and came home. Five days later they called me and told me that the 3 cylinders with the low compression had undersized pistons (a little over a 1/6 of an inch to smaller then they should be) and a blown head gasket, they said that that was something Ford should cover since it had nothing to do with the chip. Two days later they called me and told me that Ford turned it down and that the failure was caused by the chip. My dealer here in Colorado has been trying to help and said since they didn't have me sign a wavier that they would stand behind it after doing all they could to get Ford to pay for it. But now seem to be getting a run around from them now too.So I think Ford will turn down anything it has anything after market on it. What gets me is the truck in the shop just before me had the same exact problem and Ford paid for it. This truck had a chip, 5 inch pipes and some sort of engine brake on it. I'm pry screwed. Are undersized piston a common problem? The Ford dealer in Denver said he gets about two a month with it. $15000 for a new one, damn!
Thanks for listening to my rant!
Floyd
Floyd
