Twins or one BIG ONE?
lukecline
Kansas
i just dynoed 545 on ONE h2e:eek: :D
are you planning on running parallel twins, if you are i doubt you'll be able to spool them.
scotty7751
Big Daddy
NORTH Dallas, Tx
Sweet dude. well we will see its just an experiment if it doesnt work then ill switch things around. i mean i got them for free so i couldnt say no.
scotty7751
Big Daddy
NORTH Dallas, Tx
hmmm ok switching to senquencials here is a picture of the turbos
vbpicgallery.php
roosterdiesel
Earl needs B100
Amarillo,TX
scotty7751 said:
hmmm ok switching to senquencials here is a picture of the turbos http://www.superdutydiesel.com/forum...?do=big&p=1283
Ummmm...how did you pick the turbos?
What are the pressure ratios for the two turbos at the boost level you plan on running? Also what is the big turbo? I'm assuming that you will be using the Holset(h2e?) for the small one. Are you going to run external wastegate setup?
scotty7751
Big Daddy
NORTH Dallas, Tx
yes i am using the h2e for the small one and the AIResearch m-11 for the final the left one is just a polished stock one. looking for 100 lbs of boost and the turbo people im working with said it will be able to bet close to it without a problem. and yes external waste gate.
Ricksofla
