twin turbos for Powerstroke
RSW_Hawaii
Anybody know if there is a twin setup for the Powerstroke? Has anyone mounted a secondary turbo to the factory one?
I am running 12.85 et at 108-109 mph and think that more boost is the only way to get into the 11's. Any help or advice appreciated.
Big K
SDD.com Hacker/Admin
Dallas, Texas
How much $$$$$$$$$$$$ ya got?
It won't be cheap at all!
What have you done to the bottom end?
RSW_Hawaii
bottom end
Using ARB air locker rear end, 12x16 M&H slicks. ATS Stage 5 trans, FASS fuel system, 275 injectors, ATS Extreme programming, 2 stage nitrous, AFe stage 2, Basani turbo back exhaust. Heads currently being fire ringed and ported--stud bolts alone still allowed heads to lift. Even with the lift I was still getting 12's out of it.
Thanks for reply
RSW_Hawaii
turbo
Turbo is the upgraded factory one that replaced the original Garrets--works pretty well--but only gets 33 lbs. The intercooler is Banks. I was hoping for info on installing an ATS Aurora 5000 as the secondary. Some guy called Idaho CTD does this setup for Duramax.
lukecline
Kansas
check out beansdieselperformance.com he has a 6 liter turbo coming out pretty soon i think.
DiscountPowerParts
SUPPORTING VENDOR
We should have info from ATS on there new pedastal for the 6.0L. I dont know if you can abapt that for twins or not. Have a plasma cutter and welder? lol
Blksmokejunky
Alaska
Beans turbo is out I'm running one on my 05! Have seen pic of a truck with twins but was a custom job! Watch ATS there will be one soon!
TacoCat
