Ashmass,
I got my wires crossed earlier
the one by the steering column was for the door/key chime...I disconnected the seatbelt chime under the seat...but there are other ways to get to the chime
here you go:
Door open w/key in ignition chime
Remove panel beneath steering wheel , on the right side of the steering column you will find a connector with a black wire and purple stripe.
It is easy to disconnect and remove the wire intact (tape outside of connector) or clip the wire and tuck it back into the yellow sleeve and no more annoying chime if you have the door open and radio on ect.
All other chimes stay working.
Seat belt chime
Disconnect the smaller electrical connector under the driver seat (if you have power seats).
Or:
(This might take a few tries to get it right)
The parking brake is set.
The truck/car is in Park (automatic), Neutral (manual).
The ignition is OFF.
All doors are closed.
The driver's safety belt is un-buckled.
The parking and headlights are OFF.
Then follow these 9 steps:
Turn the ignition switch to ON, but DO NOT START.
Wait for the safety belt warning light to go OFF(1-2 minutes).
Steps 3-5 MUST be completed within 60 seconds!
Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled.
Turn on the headlights, turn off the headlights.
After step 5, the Safety Belt Warning Light will be turned on for 3 seconds.
Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt.
This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds.
Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again.
After confirmation, the deactivation/activation of the Belt Minder procedure is complete
This is another method like the one above, but buckling 9 times instead of 3x3
1. Turn ignition switch to the run position
2. Wait until the safety belt warning light goes off (approx. 1 minute)
3. At a moderate speed buckle then unbuckle the seat belt 9 times ending with the unbuckled position (must be completed within 60 seconds of completing step 2)
After step 3 is complete the safety belt warning light will illuminate for 3 seconds. If step 4 is not completed within 10 seconds of step 3, the belt minder will exit programming mode without changing status.
4. Within 10 seconds of the light turning on, at a moderate speed, buckle then unbuckle the seat belt. This will disable the belt minder feature if it is currently enabled.
As confirmation, the safety belt minder light will flash 4 times per second for 3 seconds.
if all else fails, you have to remove the radio and part of the dash to get to the chime...
hope that helps
