Turbo Upgrade. What do you think?
Smokenstroker
Peru In 46951
OK guys heres what im planning in the next couple of weeks. I have a 96 F-350 Stroker and i have a Ats 88mm Ball bearing turbo laying in the shop off of a 01 stroker and i want to mount it up. My thought is that i will intercool it at the same time. I think that if i change the manifold up pipes, that the turbo will mount up there and should also mount to the pedestal. Correct? And since it is the new style turbo i can use the spyder pipe off of a 01 also. Make some custom pipes to connect to the intercooler (witch i think i will get from a 6.0 because it is suspose to be bigger than the 7.3). Am i right or wrong here on my predictions. And will the Exhaust bolt up to the new turbo. Seems like a hell of a power add for couple days works on parts laying around.:stir
What are you going to do with the waste gate? I dont know that you'll see huge gains in horse, you need fuel for that. But you should see lower EGT's with the IC install.
FlorWhitfe
