silverado3500
Right, while I was accelerating yesterday (not hard acceleration) heard a sound from the turbo, and saw a puff of smoke from the tail pipe. Everything then was back to normal, aside from a whine from the turbo when giving it throttle. Checked it last night after things cooled down and found 2-3mm of play on the compressor wheel, (side to side) though there are no signs of damage to the compressor wheel, nor is there anything to suggest that anything was sucked into it. There were also no significant changes in the EGTs. The truck has just shy of 180,000 miles on the clock.
I'm in need of some quick advice on a replacement unit, as I need to get the truck running. I'm considering a Garrett GTP38R, or an h2e. However I don't know a lot about which turbo is better for what application.
My truck currently has a DP-Tuner chip on the 80hp Econo tune. straight pipe exhaust, and gauges.
I will probably add some stage 1 injectors, and the relevant tuning adjustments in the future.
Any advice would be much appreciated.
