tuners
kingranch13
tomball/tx/usa
2013 f350 6.7 kingrach.
was looking at adding h&s tuner would this be good tuner for my truck and what would I expect in problems
This will void your warranty if Ford finds this on your truck. I would wait until the warranty runs out. Others here will voice their opinion.
Dave :)
kingranch13
tomball/tx/usa
ok cool. does any know about tire off set I like the look of the tires coming out past the body but don't want it out to far and look stupid
There is two ways to do this. One use your old rims and put taller and wider tires. I used Miata.net Tire Size Calculator to do my truck. It showed tire and rim size and you could change the tire size in height and wideness to your liking and it give you the tire size your looking at. Or pull the tire and rim off the truck and use something straight on the rim and measure the rim to the hub mount. Mostly your looking at a 2" to 2 1/2". A word on this for you if you put the outside tire pass the fender it looks cool but it will toss rocks and other thing into the body area and you will be washing it a lot and fixing scratch's . I would keep the tires right at the outside part of the fender. I'll post pic on my truck when the sun is up showing what I'm talking about.
sagebel
Stock? Pfft!
Albuquerque, NM
I run an H&S on my truck with no issues. Putting a truck back to stock is not fun if you ever have to do it. Most sites or businesses that sell wheels should be able to give you an idea of what works and what doesn't. I wish I could remember the offset of the wheels I had on my '11 (in avatar). I'll do some digging to see what I can find.
1kellygillis
Alberta
I have a Spartan and that's fine as long as you don't want to go with more after market stuff like injectors and that kind of stuff. It does have some nice tunes out of the box and I don't have no trouble with it at all. H&S has more options and is very good too!
Ragin Inferno
Houma/Louisiana/70360
Dealers and manufacturers like to say that, but no aftermarket part will void a warranty unless that part is the cause of the problem. The burden of proof is on the manufacturer to prove. Look up the Magnuson-Moss Warranty Act. This is backed by the FTC (Federal Trade Commission) in other words, the United States Government.
