TS Chip Not Switching Settings
rammertide07
Rogersvilles, AL
I recleaned the contact points today and it works fine now. By it not switching programs I meant it was running stock no matter what, even my high idle setting wasn't different.
But now that it's installed I’m satisfied with everything except that in the 140 hp setting, anytime it shifts into third or fourth the shift is way too hard, like to the point where it feels like something is going to break. It feels as if the torque converter locks in as soon as the transmission changes gears, and the shift is worse the more you are accelerating.
You need to add a shift kit and you should also upgrade the torque converter before you have to.
Edit: dont forget to fill out your signature in the "User CP"...top left of the screen
