Truck won't start, Fuel pump problems?
jsa75
NSB, Florida
Ok I will try this tonight when I get home. The truck isn't here, so do you know of the top of your head the size hose I will need to buy so I can get what I need without going home and getting under my truck? Thanks for all the help.
Tbar
SDD STAFF/Moderator
I believe it is 5/16"....................
Tbar
:dunno Switch a Shop Vac hose to the Blow side.. put the end of the Vac hose over the tank fill port. Open the Water drain on the filter. Turn the key on, Turn the Vac on.. put a little pressure on the tank. Watch for fuel coming out of the Filter drain.. Slowly close the Filter drain.. let the pump run till it pressurizes (Cycles off). Start'er up. It'll Stumble till it purges but it'll run.
A 2 man deal.. or the Wife to holler WHOA when fuel comes out of the filter drain. (into a bucket/pan underneath)
Needless to say... You can push fuel to anywhere in between too ?
Shade tree as hell.. but it works.:dunno
jsa75
NSB, Florida
Good idea, thanks. I was working on the truck when I locked my only set of keys inside =[ I will try this trick after the locksmith arrives.
iracemine
black and tan
Cheese Curtain
really???:lmao :lmao :lmao
Brad1103
