jpclwill
jpwill
Hello,
I have been reading over the threads on and off for quite a few months. I do not post much since I am basically learning from all of you. On the way home yesterday, I stopped for a car that was turning and went to step on the go pedal and it did not move. Still running, but will not move only a a tiny crawl. Pulled into a gas station, and noticed that it will idle & engine will rev up in neutral/park, but soon as you put into gear...no move. ALso, puts out lots of smoke out the tailpipe and runs rough when in gear. Check engine light came on shortly after this happened. Truck was running fine before this happened! Any ideas? I had it towed to the dealership, but I kinda of would like a heads up so am not getting raked over the coals. Your help is greatly appreciated.
