truck pics
nascar_fan28
IL
haha... yeah its not that big... but i wanted it to fit in a regular garage... plus i load alot in it... it was easy to install lift... just undo sway bar shocks.. pretty much drop axle far enough to get springs out... still had to compress springs lil bit... through in blocks... bolt everything back up.. had to do lil cutting on shock mount... rides exact.. no difference, nice thing with 2inch lift.. has lil lean to front.... ive seen way too many fords riding higher in front then rear... lol looks like there loaded when there not.. makes me laugh
nascar_fan28
IL
not perfectly level, but i haul alot so when i have load its pretty level..wish i had chevy then i could just get a wrench and crank torsion bars... and bam level truck...
nascar_fan28 , where did you buy your lift kit and what do they cost? I have a 06 350 and would like for it to be level.
Wood County Tx
doug that means you dont have enough hitch weight out back :D
:roflmao
load that puppy up :D , whats a coupl 3-4k lbs out back :D
Yep, That's maybe what I need to do. Just found out that we will be leaving the rally on Sunday and going to MO. to pick up the new to us trailer. It has a hitch wt. of 2600LB That should sat it down just a little.
Wood County Tx
now your talking that will even the ride some
makes them four rear tires really grip the road.
post some pics of the new fiver :sweet
sweet looking truck
jkmcgrath said:
Real sweet looking truck!
Thank you, Thank you very much, in my best Elvis voice.:thumbs
And thanks for coming by SSD.com Come back often. We like to help you spend your money on your truck. We are good at it.:sweet :roflmao :roflmao
Ricksofla
