easyrider1234
6.0 stock setup
03 F350 6.0 stock engine, no mods....I started having an issue with my truck dying going down the road. It first happened pulling on to the freeway once I got up to about 60, died, i put it in nuetral and it started right up but it kept doing it again and again. It seemed more prevalent on grades. I thought that it could be possibly the fuel filters, so I changed the oil and filters thinking that would fix the issue. No such luck, then I wondered if air was in the fuel line(I never got a straight answer on how to bleed the air out after new filters). It seem to go away for a while, I recently moved and hauled 4 large loads about 30 miles each without it ever dying once. The day after it started doing it again. Now after it warms up it wont drive 5 minutes without dying.
A possible related issue? I have had a check engine light on for a month or so that I had checked out at a NAPA dealer. They said it was " faulty IPC unit"...I looked into them and they are @150 bucks (which I dont mind buying). Two issues though, it seems like a pain in the butt to get to and I dont want to waste my time or money if that doesnt fix it. ANY IDEAS????
