Trouble with Ford dealer
HELP WITH SOME ADVICE 6.4
  • respond
    Votes: 0 0.0%
  • Advise
    Votes: 0 0.0%
  • Total voters
fe427
Charleston S.C.
Good day looking for some advice we took our 2010 f-550 with 6.4 to the local Ford dealer we had a check engine lite on and an intermittent battery light truck was running good and we never had to jump the batteries to start it just wanted to make sure we were not ignoring the warning lites and causing any damage this truck has 174000 miles on it and about a 18 months ago had a new Ford crate engine assy installed and both turbos were replaced so we were pretty confident the crate motor and both turbos were ok. well after the Ford dealer had the truck for 3 months they had a bill on the truck for a little over 10 K . and now the truck will only go about 2 miles before it shuts down so they told us they cant fix it and to come get it with a wrecker remember when we took it in it was running good we were using it every day their explanation is the truck has a tuner in the computer and they cant fix the truck because it is not a ford program they have replaced both turbos, a door lock alarm module, alternator, brake light switch ,EBP sensor and fuel filter and are adamant that it needed all these parts even though it made the truck run worse any ideas ? thanks Hugh
Skram
