trouble codes
roosterdiesel
Earl needs B100
Amarillo,TX
95_stroker said:
Correct you are Crumm, only posted NAPA's link to show price, someone had mentioned that it was only about 5 bux less than Ford, and that didnt sound right to me. Also, NAPA is right down the street from most everybody, so if it was a "gotta have it right now" item then there it is.
I posted that...my NAPA must be making some $$$.:dunno
I'd take a printout from NAPA online in to your local NAPA and when they wanted to charge you an arm and a leg, show them the online pricing.:sweet
250stroker
Uhm,,,Excursions do not have GPRs. They have the GPCMs. If you are getting codes for both side circuits, then the GPCM is bad. :sorry
doug young
Snohomish, Wa
hey boys, since we are talking rouble codes i would like to add mine if thats ok.
p1211
p1212
found something on the internet about ICP sensor fault and ICP pressure too high or low. can you help? not sure if these are right and what is ICP?
thank for letting me piggy back on this thread
doug
Doug,
ICP is the injection control pressure sensor. Its located on the left head towards the front. For one reason or another you had either low or high pressure in the high pressure oil system on the truck.
Doug,
Its doubtful that it was something that you did unless you recently worked on the high pressure system, such as the IPR valve or did injector work where you may have drained the oil rails.
It can be caused by bad orings on your IPR valve or a sticky IPR valve. But you will usually get a rough idle or poor performance with this condition.
Mike
doug young
Snohomish, Wa
mike, i havent worked on anything along those lines. so is there anything i can check? this is really a new one for me and i am totally lost. first of all, i dont even know what these sensors and regulators do, so you will have to really spell it out for me.
doug
Doug,
Is it running rough, dieing on you or are you experiencing some other type of problem with it? What led you to pull the codes? SES light illuinated? When you clear the code, does it come back?
Mike
