Trouble Codes
Ironmerganser
Ironmerganser
Omaha, NE
Had the idiot light come on today. Hooked up the Bully dog and got two codes:
P0603 - ICM KAM
P1000 - OBD Reset
Any insight on these????
Thanks in advance!
Ironmerganser
Ironmerganser
Omaha, NE
Well.....I hooked it up when I got it and put the truck in "Performance" mode with "smooth" shifting for the transmission. Is that what you mean by all the time?
I looked up the codes in the WIKI section:
P0603 - Internal Control Mondule Keep Alive memory
P1000 - OBD Monitor Testing Incomplete
Now...the P1000 I am assuming is from me hooking up the Bully Dog to get the DTC's and not completeing it. But....does anyone have any insight into the P0603 and what that means?
atk
Moderator
simcoe, ontario, canada
what i would do is put back the stock programming and clear the codes. drive your truck with the stock programming and see if you get P0603 back....i have been getting the same code when i have one of my tunes from my Livewire loaded, but no CEL(knock on wood). truck runs fine and if i run the stock program, no code....i am going to contact SCT tech line to see what they have to say....you can always try contacting Bully dog and see what they have to say....hope this helps
let me know what happens in the stock programming....
TacoCat
