Trip report.
Just got back in two days ago from a 2200+ mile trip in the PSD with the TT in tow. This was my first time towing with the addition of both the Stg I's and the wildman chip. Last year I had the Stg I's but was only juicing with a SCMT. Last year it was pert near impossible to "get too much" with the SCMT. But with the chip/Stg I combo this thing was a towing MONSTER:burnit . This was a pretty rough tow also, right through the heart of the Rockies from Central Wyoming on up through Western Montana into Northern Idaho and our destination was Kettle Falls Wash. We did mostly interstate driving but the first 300 miles of the trip was secondary highways on into Red Lodge Mt. That first leg of the trip I took it easy on the throttle just to get the feel of how the Pyro/boost were going to act. I stayed mostly to 65 mph and got between 11.5-12 mpg:thumbs . I know it seemed like the truck liked to run at 75 better while on the interstate, the RPM's were just in a better range to handle grades and such. I think at 75 I'm turning about 2300 rpm's and at 65 its closer to 2000 rpm's. With the cruise on @ 65 if I hit a good grade it wanted to kick down out of OD and then the pyro would just wrap right around, however @ 75 when I would hit a grade the old girl would just toss in some more fuel and the boost would begin to increase and the EGT's would stay more managable. Matter of fact, @ 75 I had to keep a pretty close eye on the boost, on the flats it would run around 10 psi but on a good grade it would want to push right upto 30 and the EGT's would hang in the 1350 range. So I would have to feather out of it to keep the boost managable. Now the bad news, she likes to run 75, but she's thirsty @ 75, to the tune of about 9 mpg.:eek: At one point I came across a new(er) Dodge pulling a flatbed lowboy (28-30 ft?) with a mid 70's model Chevy and some scrap iron on the lowboy, we were both doing right at 75 but I kept creeping up on him when he would get to a grade. Whats a poor boy to do??? I turned the old girl loose and let her run, the first grade I came around him he just kinna looked at me like :confused: ........ We came off that grade and I think he was a little miffed and he sped upto 80, I stayed right where I was at and about 3 miles down the road we hit another grade and guess who I met again.:D This time he got the whole enchilada from my 12 year old beast:burnit and after that second grade he didnt show his face again.:hail
Bottom line with the injector/chip combo is that this is one terrific towing combo. I however DID frequently set the CEL and am positive that it is my HPO. I do think an intercooler would be helpful in both controling boost and egt's but not mandatory. At least not madatory enough to warrant a $750.00 upgrade unless I towed ALL the time.
On our return trip home near Buffalo Wyoming we ran into a damn hail storm and got the front of the TT beat all to snot:rant , didnt dent the pickup so I was thankful for that. Other than that tiny little hiccup, it was a safe, uneventful trip, no break downs, no accidents, no run in's with the :cop .
Notes, observations and pearls of wisdom picked up along the way:
Unscientific data here but, it seemed that about 7 out of 10 rigs on the road that had something in tow were blue ovals. After that, I would say that the Duramax was second. There were a TON of Cummins on the road, but they were all empty:dunno musta broke the hitches off the trailers with all the power.:rolleyes:
Five people in a CC can get a little uncomfortable, especially after stopping at Taco Time for lunch.
If you forget to hook up your saftey chains and drag them 40 miles, you WILL lose one of your quick links.:oops:
If you forget to lock the fridge, it will come open and the salsa WILL spill on the floor.:cussing: both times.
There are alot of mosquitos in Northern Idaho.
Fuel pumps shutting off at $75.00 is a major PITA.
Christie Brinkley never did zoom up in a red Ferrari and flirt with me.:dunno
94f450sd
certified nutjob
plymouth,ma
sounds like you had a good trip.the CEL is most likely for the HPO but we are still working on the fix for that:D .
an intercooler would work wonders for you but like you said"i dont tow all the time",and you dont drag race either so it would be a waste for you.if you were running stage 2s then it wouldnt be a waste.
ya i know,i read the cellphone,public restroom story on OB :roflmao :roflmao
hheynow
Señor Aceite de Soja
Northern California
95_stroker said:
Just got back two days ago from a 2200+ mile trip in the PSD with the TT in tow. ... I stayed mostly to 65 mph and got between 11.5-12 mpg :thumbs . ... Fuel pumps shutting off at $75.00 is a major PITA.
What's a fuel pump? :dunno
I don't use them any more. :D Looks like you had a great time.
2200 miles @ 9-12 mpg........ unless you can haul 250 gallons you'd soon remember what a fuel pump is. And yes, we had a great time.:thanks
Roland_Jenkins
Washington State
Needs to save up and get a detroit locker :roflmao :sorry
roosterdiesel
Earl needs B100
Amarillo,TX
95_stroker said:
...Matter of fact, @ 75 I had to keep a pretty close eye on the boost, on the flats it would run around 10 psi but on a good grade it would want to push right upto 30 and the EGT's would hang in the 1350 range. So I would have to feather out of it to keep the boost managable...
What no 35psi this year?:dunno :roflmao Trying to keep your turbo work intanct?:D
Glad you had a good trip!:sweet
Oh, it would rocket right past 30 on the way to 35, I had to feather it on the long hard grades to keep things in check. I couldnt get 35 out of her last year with the SCMT...... bout the best I could manage was 25 and to be honest with you, I dont know what killed my turbo last spring other than age.
Roland_Jenkins
Washington State
He toned down the bragging a little from when I saw him. Was claining he had to run the engine brake going uphill.
Thanks for the report :sweet I am liking the sounds of those injectors. What have you been getting for mileage lately running empty?
That is for sure. I have been wondering with todays prices why they don't up the limit.
