transmission trouble
rev_propane
houston
got a 97 350 and just put a 3' down pipe and 4' exgusht all the way back. when I put my foot to the floor the trans will up shift instead of down shifting, it will also shift eary when at full throttle. It also has a programer installed it. All this started after the new exgusht was put on. any help is appreeciated.
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
This may be a stupid question, but did you or the installer unplug anything under the truck, or inside when installing exhaust? If a shop did install it, who knows what could have happened. :[
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
Yeah, taht would be the first thing to check. If not that it may be something simple but, then it could be very costly:(. Good luck, and if the installer did unplug something or screw something up, I'd be looking for some money back!! Good Luck.
TacoCat
