NASCAR Mike
My 05 Excursion hit the 30k mile mark and I thought it was a good idea to change the transmission fluid.
I looked online and saw that the Torqueshift hold 22 qts of Mercon SP. I bought two cases at my Ford dealer along with a frame mounted trans filter and the pan trans filter.
I drained the pan and removed both filters. I blew air into the lines to get out as much of the fluid as I could. I was unable to drain the torque converter but I was thought that blowing air ino the lines would help displace it.
I added 7 quarts of trans fluid and started truck, moved shifter into R and D a few times and recheck fluid.
After a 30 minute drive I check fluid and ultimately I only needed to add 10 quarts total.
Does the trans really hold 22 quarts? My chilton book says 17.5 quarts.
Is replacing 10 quarts enough?
