Transmission Fluid
02Oilburner
SDD Power Hungry
Raleigh, NC
I changed the oil today and have been thinking about the transmission fluid. I have the BD power deep pan.
BD Power - Product: Transmission Pan
It says it holds 3.5 qts more fluid. How much ATF do I need for a fluid change? I had red line ATF put in when the transmission was upgraded/rebuilt but dont know which one they used.
Red Line Synthetic Oil - Automatic Transmission Fluids
Which one of these would you use or which ATF do you recommend?
Thanks everyone!!!!!!:D
Valvoline MaxLife Mercon
get 24 quarts..
You're going to need 20+
trackspeeder
Stone Crusher
North Branford CT
Your tranny will not have a drain plug in the converter.
Follow the 4R100 flush article in the SDD Technical WIKI.;tu
Valvoline Max life, Mobil 1, are real good. If you use Red Line. Make sure it is Mercon or Mercon V rated.
trackspeeder
Stone Crusher
North Branford CT
Don't forget your transfer case. It uses the same fluid that you are pouring into the tranny. 2+ quarts, if I remember correctly.
02Oilburner
SDD Power Hungry
Raleigh, NC
Man I forgot that was in there!! Thanks!
02Oilburner
SDD Power Hungry
Raleigh, NC
22 quarts for transfer case? Holy SH!t! Its going to be an expensive week spent on fluids!! $120 for oil and filter, $120 for trans fluid, $125 for transfer case!:eek:
Oh well I guess I saved a sh!t load by doing it myself!
no, 20+ for the trans, 2+ more for the t-case..
that's why I said 24
