JSPulliam21
Uva Uvam Vivendo Vari Fit
I will be changing the tranny fluid in my dad's 02 350 CC 4x4 DRW soon. We have installed a 6.0 cooler and changed the standard Dexron III/Mercon every 30k miles since he bought it. We are considering going with the Amsoil Universal ATF, as he has Amsoil in the diffs and transfer case and is happy with it. Amsoil claims you can go 100k on a fluid change which would offset the higher cost, hassle of changing out 3 times the dino oil, and he would have the best protection there is. I want to hear from you guys that have run Amsoil in a stock transmission for a long period of time. I am concerned about the stock components with the "universal" dual rated Mercon/Mercon V fluid. So, let's hear about your Amsoil ATF experience, good or bad/-popcorn
