transmission cooler line, 99 7.3
Guinness
superdudiest
GlenMoore, Pa USA
I have had no trouble with my truck in the past and recently got a pretty large trailer to pull. Since then I noticed a long trail of transmission fluid coming from a cooler line.
I first loosened it, then tried to snug it down and apparently made the leak alot worse, its now gushing out.
Anyone have any idea where I can pick up another line on a sunday, I need to use the truck in a few hours? I have a flaring tool to put a new flair in the end of the line but I believe I dont have enough to redo it.
Also how much tranny fluid is in these things? is there any way to stop the flow (plug it up?)?
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I usually takes me about 12 quarts when I change the fluid.
Where is the leak coming from? At the trans at the cooler line fittings? A possible temp fix might be to just put a piece of trans cooler hose and some hose clamps in place of the hard line until you can make a more permanent fix.
Guinness
superdudiest
GlenMoore, Pa USA
The line snapped in the coupler at the trans on the passenger side rear. Im having trouble finding anything similar to what is on there which seems to be aluminum tubing 1/2 od. The flair in the coupler gave out and doesnt leave me enough to redo it before the bend toward the front.
Im at the point now where I have some fittings from homey depot and trying to piece it out.
Anyone have any experience with copper tubing? will it take the pressure? Im sure copper is stronger than the aluminum thats on there now. I can get copper pretty easily in 1/2 od.
Since its aluminum tubing I dont think I will have any luck piecing it with rubber hose then trying to clamp on it, I think it will crush.
RacerX
AMERICAN INGENUITY
South Carolina
Hopefully your fixed by now. If not, and i understand, the line broke in the case fitting. The line size is 3/8. A simple fix is to get a short double flare line and a brass union. Cut 1 flare off. Cut the OE line back and splice in the new line with brass unions.
FlorWhitfe
