Question Trans trouble
boluke10
East Earl, PA
what does it mean when the tow/haul light is flashing? Is this a sign of torque converter slipping?
rammertide07
Rogersvilles, AL
Possibly....could be anything with the transmission.
Is it doing anything...... Whine/moan when accelerating? Shuddering under a load??
I would get codes pulled ASAP
VSS (Vehicle Speed Sensor) It is located on the top of the rear differential and very easy to replace. About a $30 part. Unscrew it and put the new one in and make sure the connections are clean.
Very common issue and a flashing O/D or Tow/Haul light is usually the signal.
If you've got ****ing issues, you might have internal problems.
haha...i think i meant to type shifting. freudian slip! sorry admins, no harm meant.
