JRJ04,
I was going by the factory gauge..When the temp spiked, and the check gauge light came on and the tow light on the column shifter started flashing, the tranny drove like it was in tow mode. I did look under hood and found a mouse nest ont he passenger side under hood and there is some sort of vacuum device fight bt the nest. This was making an unusual noise. The device had a white tee attached to it with an open end. When I put my finger over the end, the vacuum noise changed to sound like a more normal noise. I looked for chewed hoses but have not found one yet. I was wondering if there used to be a plug on the end of the nipple that the mouse may have removed cauisng the problem. I never smelled anything that would be an indicator of tranny fluid getting hot. I checked fluid and it looks good not dark and does not smell like burnt cork. Any moe info greatly appreciated. Have a great day.
