Tranny Problems
smokin joe
Smokin.....
Fox Valley, Wi
I dont know what happened but when I was driving it I started to shift it from 2nd back to drive a quit a few times and now it seems to be working fine. It was a little low on fluid but not that much where it should have made a difference. I dont know if something was stuck or what but it seems to be shifting good as new.
I guess I'm a little at a loss as well, you arent getting a flashing OD light? I would be inclined to drop the tranny pan and then pull the vavle body to see if the valves are gummed up or if you have a broken spring.
edit: looks like we were posting at the same time, hopefully your problem is fixed.
smokin joe
Smokin.....
Fox Valley, Wi
Im not getting any flashing lights. I was planning on dropping the pan when the bad weather goes through and clean everything up.
