tranny problem
snowrider
michigan
tranny
Now that the light has not been flashing.It is shifting smooth not slamming hard in gear.But I found out my rev limiter works had cruse set and it quicked out and the rpm went 3700.Shut cruise off.And went slow home.I think I'm going to put shift solenoids in.
If you have the ability, pull the codes, if you dont have the ability then go get the codes pulled. If the OD light was flashing, there was a reason. The code will tell you the reason and we can help you with the fix.
