Anyone use one of these pans? Thoughts/ suggestions all welcome. Thanks.
Ford E4OD / 4R100 Transmission pan cooler Makco Transmission Parts
I ran that exact tranny pan on my 02 except mine was made be derale. I ran it, re-routed the tranny lanes out of the rad, retaining the factory cooler and then used two aftermarket tranny coolers with a pusher fan up front right behind the grill. As hard I drove it, even in on the hot summer days I hardly ever saw tranny temps over 150*.
The general rule of thumb is if you increase your fluid volume you should also increase your cooling capacity as well.
Save your money and use the stock pan. Take the money you saved by keeping the stock pan and put it into a better tranny cooler.![]()
