TorqueshiftTranny fluid question
05TowBoss
What is the fluid capacity of the stock torqueshift tranny pan?
I just replaced the stock pan with a PML pan and wnat to know how much Mercon SP to add the 4.5 extra quarts the PML holds.
Thanks for the help...
teamroper60
Troy, MO
My owners manual says the TorqShift holds 17.5 qts with an external filter change. I would imagine it would be similar for the 05s as well, but your manual should be able to tell you for sure.
Hope that helps!
05TowBoss
Hope that helps!
I think thats full capacity...I just need pan capacity...thanks though...
05TowBoss
I answered my own question...the pan holds 6-7 quarts...so with my PML pan it holds 10.5-11 quarts...
I checked it cold and it was at the top of the cold mark...I'll let it settle and check again...
Then I'll check it hot...
hitecdan
Campbell, Ca
If you pull the plug on the stock pan, about 7.5 quarts will drain out.
Skram
