Torqshift problems...
elliotthere
Bitely,Mi
It was serviced not too long ago, and the fluid is where it should be. I don't remember the grade of fluid, but it is Amsoil and the service was done by a powerstorke specialist.
These symptoms are fairly new which leads me to believe it is an internal problem.
When you had the trans serviced did they drop the pan & replace the filter? If so, the filter may have come loose and dropped down, just a guess. I haven't worked on this trans before, I retired from Ford dealer in 99 back then it was E40D. good luck
Dave (elliotthere)
Brians Truck Shop
BTS Changed my truck out at 30,000 and he only uses
Schaeffer ATF and I now have 63,000 and it's still
doing fine, and most of you know that my truck pulls a big load.
Zmann ARGH
AZ
I can not find one Schaeffer ATF??? that actually doesn't say DO NOT USE FOR SP
http://www.schaefferoil.com/datapdf/204SAT.pdf
these transmissions are very susceptible to shudder issues
Dave the filter on these is in the front frame area the internal element is a screen so standard fluid change is a heated flush and frame mount filter change
elliotthere
Bitely,Mi
Thanks for the update
Dave (elliotthere)
OneTonKingRanch
OneTonKingRanch
Port Orange, FL
I guess it could be any number of things...Ill find out tommorrow when I drop it off...
It is quite possible the thing was fried when I bought the truck. I am hoping for the best, but expecting the worst...If a rebuild is needed, I will upgrade it so I can really turn up the wick! Ill try to make the best out of a bad situation:dunno
Zmann ARGH
AZ
they are tough transmissions
good luck to you and your wallet
