Frankenstien
Frankestien
1997 Mercury Mountaineer, Most times Brakes OK... some times to the
floor... Here the Skinny, 98% of the time Brakes function normaly, no
pulling good foot preasure, then for no reason you go to use the brakes an
your foot goes nearly to the floor , one pump and your back to normal.
This condition exists Hot or Cold, Wet or Dry ... I have taken the
following actions, checked wear on all pads, 75% + on all 4 Blead the
brakes... all 4 the fluid looked clean when I started ...looks a little
cleaner now no leaks, hear no Vacume leaks.. all 4 calipers actuate
freely. ... I changed the Pads about a year ago... I did not remove the
bleeder screw as it was suggested in some of the Posts that I searched, I
would have thought tho if my problem were related to bad fluid in the ABS
sstem it would have shown up long before now. any way kinda thumped on
this one... Things I have concidered but have since ruled out: Air in the
lines...
Lost Caliper Pin
Cracked or Broken Brake pad
Contaminated Brake Fluid
Leaking Calipers
Hoping one of the followers of this forum will have a clue as I no longer
have one... :-(
lines...
Lost Caliper Pin
Leaking Calipers
have one... :-(
