Tire size question
Diesel Kinevel
97 Stroker
Frederick Co. MD
my 97 will be needing tires in the future and I want as big a tire as I can fit with out rubbing being an issue. I was planning on putting on a leveling kit eventually. will the leveling kit produce enough lift for a 315 or maybe a 305? thanks for the input
Darth_Stroker
Dark Lord of the Sith
Manor, TX
I've got 35's with an add a leaf and re-arch in the front I think thats the same as 315's I've rubbed the chrome on the under side of the fender once or twice. I would think stock suspension 305's would be max. I'm sure some one with more expertise than me will chime in.
Alan
stroked 350
coventry,ct
i have 285's on mine i was told by the tire shop that 305's would rub on the front bumper. good luck chuck
fordtrucker4life!
I work with waste
SE Michigan
I've got 285 BFG's on mine and they hit the bumper. I had to space it about 4-6 washers I think.
Edit-
F250's have the Dana 50 and F350's have the Dana 60 front ends. The 285's may not hit with a Dana 60.
action4478
Muskegon Mi
I'm running 305 with recurved (new ) plus the add a leaf. Previous owner put them on, & also trimmed the front bumper a bit
.They rub on the springs it tight turns
By shimming the front bumper out and adding a leveling kit (add-a-leaf) you can fit the 315's. The 305's will fit by just shimming the bumper out a bit.
Diesel Kinevel
97 Stroker
Frederick Co. MD
where can I get shims for the bumper? are they the same kind of shims you use to mount fenders?
edit: and how many shims do I need for each side?
I used washers and longer bolts. Seems like I put about 1/2" or so on each side. Take a look under there and it will be obvious what you need to do.
hdjeff
Medina, Ohio
i have 265's i didn't feel like shimming or doing any mods when i put them on. they fit fine and no rubbing anywhere
