Tire pressures
Wood County Tx
empty dually
60-65 up front
40-45 rears
loaded
65-70 up front
rears based on load across axles
45 and ^
a great rule of thumb is if your not going to be LOADED all teh time and can take the time to air up or down depending on load.
is to air up the tires based on load
most mfg have this info on their site. mich and good year bfg
but
the fronts like its been said are HEAVY , so run em up near max
i like 60-65 but ech tire is differnt based on plies and construction
so if you start at say 60 psi then lay a flat ruler across the tire tread at the top.
the tread should be just north of concave.
then look at the tread contact at the ground, (it helps to be on flat concrete for this)
the tread should be even across, the middle and edges should share the contact with the road.
if the center is touching but the outer edges are not, then your running to high of a pressure based on the load.
this will not be to detrimental except you wear out the center tread grip surface faster than the edges
and is the edges are touching and the center is not, then your UNDER inflated and this is bad for tire life and safety.
a note about fronts on 2wd trucks (ford) the twin i beam setup is hel l on front tires
it wears in a weird odd ball pattern
bad or weak shocks will cause them to scallop the outer edges, and if your driving like #3 the outer edges will wear right over into a nice curve and eat up your rubber
its very important to air up the fronts to keep a nice slighty more raised center tread when measured at the top.
all you guys running oversize tires and wheel
your on your own.. follow the recomend psi from the wheel company and tire manuf.
i know for a fact my last set of mich atx 10 ply 16's i ran with 30 psi out back empty and they wore very envenly
dually trucks can run at very low PSI empty because of the load share between four tires.
a 2400 lb tire at 80 psi theoreticlly balances out to 30 pounds carried for each psi .
wow wrote more than i thought
one more disclainer
tires above 18" wheel diameter, are a whole nother ball of wax
20's are rated at less capacity and proper air pressure is VERY VERY important. with less sidewall to absorb the load surges.
http://www.rma.org/tire_safety/tire...y_brochure/tire_care_and_safety.cfm#inflation
great article
HCAbowman
Fayetteville, NC
I have found that the best range for my Ex, is 76psi in all 4 corners, It may ride a bit rougher, I have the Michelin LTX M/S LT/E also, and that is the sweet spot for these tires!
02EX_PSD
Not as Junior of a Member
NW San Antonio, TX area
Thanks for everyone's input. I left the tires at 60 psi and we just got back from a road trip. I didn't see any improvements in MPG but felt an improvement in handling and the truck did not "wander" in the lane like it used to do. Overall I like the way it drives with the tires at a higher psi than the factory suggestions with these oversized tires.
Thanks again for all of your responses!:hail
TexasExcursion
GOD Bless America!
West Point, NY
What do you mean by the "sweet spot"? How did you come up with 76psi? :confused:
ranger boy
Banned User
I put 72.05358 psi in my tires, quit raggin on him LoL
Nah I usually put 5-10 less then max psi in the tires, which is from what I'VE heard works the best.
draftlover
Crybaby
Wyoming, U.S.A.
FastColts said:
The front tire pressure needs to be at the factory recommended psi (door jam sticker) because of the weight of the engine. Rears are a bit more flexible depending on the weight of your load. I put 45 psi when unloaded and bump them up to the max rating on the sidewall when loaded. Under inflation will cause wear on the outsides and over inflation will wear the middle.
I don't want to sound mean and I'm not attacking FastColts, but I think this is where Ford is messing up:cop . I'm sure everyone remembers the "Rolling Explorer" incident, where Ford blamed Firestone for the tire failure and somehow won a lawsuit against them!?!?!:eek: Ford was recommending less pressure in the tire than the manufacturer of the tire. I don't know what the judge and jury were thinking... but don't you think the guys who made the tire would know more tecnical data about it than a company who buys them for their vehicles?:dunno (Firestone has been making tires as long as Ford has made cars.The two companies had almost a 100 year history of tire contracts.) Ford was trying to get a "smoother" highway ride out of their vehicle by using less tire pressure.(I'm not knocking the company, I own two Fords. Just questioning their judgement.) I personally owned Firestone Wilderness A/T's that I had on a Toyota 4-Runner, they were the longest wearing, best AT tires I've ever owned. Not so much as a nail puncture in 70,000!! Sorry, getting off topic:rant ...anyway...My :2c go by Tire Manufacturer specs, NOT an automobile manufacture's "door tag". They designed, engineered and built the tire and should know it's requirements and limits. You wouldn't want the tire company telling you what kind oil to put in your Stroker would you?!:thumbs :nono:
TexasExcursion
GOD Bless America!
West Point, NY
Wow, you must have a pretty good tire gauge, mine only reports in tenths. :roflmao
I was asking about the 76psi because I'd heard of a ______ tool that you can use to determine the best tire pressure for your tires, load, etc, and wondered if he used that or just SWAG'd it.
Ricksofla
