Hi all, been traveling a lot of late and my truck is stuck in the driveway. Fortunately that is where the accelerator peddle stopped making the engine speed up, when I unhooked a trailer.
I ordered a throttle position sensor from Ben at Wabash here:
throttle position sensor, f250 pick-up - 1999-07 super duty - 1999-07 SUPER DUTY
99-04 $68.56 $37.02
But Ben called and said I needed a different unit that included the accelerator assembly, at around $75. I said ok, he sent it and when I got home Friday night the new unit is nothing like my old unit. Different number of pins on the cable, different bolt configuration, etc.
EDIT: 1C3Z*9F836*C 56003 Pedal $77.10
Anyone have a part number and some experience on this, for example is it possible to just replace the sensor? Also, should I be checking anything else beside the TPS as a culprit. I started the truck after fiddling with the sensor just to see if it repaired itself while I was gone lmao). Truck starts but no gauge lights. I don't remember that being a problem when it quit in the driveway 3 weeks ago!
Thanks in advance for any ideas or tips.
99-04 $68.56 $37.02
