This is a hard one to figure out ! !
There are 2 codes I got. Dont know what they mean or if they are any good but here they are.
1) 01-P0603
2) 01-P111
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0111 Intake Air Temperature Circuit Range/Performance Problem
smokin joe
Smokin.....
Fox Valley, Wi
So what can I do to fix this?
I ALSO just found out I have another problem. What I thought was an oil leak at the rear main has turned out to be a FUEL LEAK. I noticed it dripping off the back of the engine so when I looked fuel was sitting in the valley under where the fuel filter sits.
Any ideas on common problems or where to start on that one ?
johndeerebones
GOT PMS?
Farmington, MO
The most likely culprit is the fuel pump, other than that, the fuel filter bowl itself has some rubber fuel lines at the bottom back that are prone to leaking. There are also plugs for the fuel rails at teh rear of the heads that can leak, if you look up from the bottom you can see them, or feel them from the top, they take a 1/4" square drive.
smokin joe
Smokin.....
Fox Valley, Wi
Thank You I will give it a shot.
