SD70M
SuperDuty
My problems started, soon after I bought the truck. The PO ran WVO in it and I run a WMO blend. Soon after putting my fuel in the truck, the WMO blend cleaned the VO residue from the fuel system and some of it had the FPR plunger stuck open. I only had 16PSI of fuel pressure and ended up starving two sets of injectors and having several hang slightly open. I had bought a core set of AD injectors and planned to use them to buy some new ones. I ended up having to put them in the truck, to run them as long as I could.
Last Thursday, I bought and installed the new set of AD injectors and everything seemed great. Went camping and after around 200 miles, it started smoking again and getting worse.
I have 62PSI fuel pressure at the test port, close to the #1 injector. IPR at idle, is 8% and ICP at idle is 480. It really smokes bad at low RPMs and I have no idea what else to check, not to mention the serious lack of funds.
The fuel I'm running is about 95% diesel, so I know the oil isn't too thick in the fuel.
If anyone has any ideas I can try, please let me know..
