Eubee
Well, the dealer claimed that the HPOP needed replaced as does one injector. So I pulled out the pump, but I do not see anything physically wrong with it. Is there any tests that can be done (out of engine) to determine if it is building enough pressure or not? I personally feel that the pump may be good, and that there is a leak or bad part elsewhere. ICP read 550PSI durring cranking. Truck is a crank no start.
Any help is greatly appreciated.
Thnx
Thnx
