Eubee
Anybody know if the high pressure oil rails have any rubber orings in them? Other than the ones on the plugs that can be removed. I 'cleaned' mine out, and now there seems (to me) to be too much play between the rails and the fittings (nipples if you will) that go into the injectors. Anybody know if that might be normal?
Thanks for any help.
