TC lockup light?!!
96EDGEpsd
Welding/Fabrication
New York
well its sunday and im bored so its time for another small project...i was wondering if i can put a toggle switch somwhere to KEEP the tc FROM locking untill i want it to, can i just put it in the same wire as the led and stop it from locking?! imo it locks too early..
JOAT
I Found Nemo!
The West Coast
Yes and maybe, the PCM grounds the TCC solenoid thru that wire. But if the PCM calls for a TCC lock, it monitoors for unexpected change in road speed for the RPM being seen. If it decides there is TCC slip it will put you in limp mode, tho you may be able to get away with it just for acceleration.
Won't hurt anything to try it. Let us know how it works out.
Ricksofla
