hondo1312
If you ever disconnect the electrical connections on the bottom side of your master cylinder, please be aware that they are interchangeable. If you put them back on and accidentally switch them, you will get an annoying TBC Fault every time you touch the brakes and your cruise control won't work.
I just spent 3 hours (and thankfully no money) to figure that out.
Hope that this helps somebody down the road
