rsomerville
I have been told not to use synthetic oil in the 6.0l, but when I purchased the truck the previous owner used synthetic oil. Can I go back to regular oil or not??
BS, you can run synthetic oil after you have some miles on the engine. Works like a charm.
I would tend to disagree. When you use a synthetic oil the seals, o-rings and all other oil soaked surfaces rely on the additives in the oil to make the seal, when you change back to regular oil the seals, o-rings and all other oil soaked surfaces are robbed of those necassary materials which will cause them to crack and become weak, causing leaks and sealing problems. Plus with a huei engine especially the vt365 that relies greatly on oil to run and lubricate your best bet is to stay with the synthetic oil, you can downgrade to a blend because it still has the essentail additives in it.
