switch on hot wire
hammerdown
Loc: 39 24' 34.8" N 88 47' 51"
Where can I find a hot wire with the ignition switch in the run position? Behind the inside fuse box somewhere is where I need to be. I don't want to use an upfitter switch cause it needs to be hot at all time and just maybe with the upfitter switch it would get shut off. Any help. Thanks Carl
Northeast Texas
what are you wiring up? and its expected load?
either way if you pull the cover off the dash where the electric rear slider and shift on fly switch is, there is a wire that is HOT at all times,in the connector for the esof switch, but they are a smaller gauge so you would need to run a relay off it and a heavier wire to the item
aslo the 12v power outlet is LIVE 24/7 you can tap off it to
FlorWhitfe
