Suspension lift to clear 38"s
keanoknick
Big Stroker
Cowtown TEXAS
Make sure you get a tire that is ATLEAST a load range D, prefferably an E.
As far as the steering issue you mentioned, I have never seen it be a problem on an 8" lift (I have no problems with mine) but if you go any higher than that, you need to get a crossover steering kit, and it will eliminate any problems, you can do up to a 22" lift, maybe bigger and not have steering problems.
MidwestOffroad
MN
Yes with 8" lifts it is recommended to run a x crossover steering system which replaces the pass side knuckle drag link and pitman arm, and relocates the drag link over the spring for less stress on the steering sector, which could break while driving down the road,
If that was to happen the truck will have no steering.
8" is recommended but anything over that it is required.
If your going to 37" you will want to run a 6" lift, you still may have some slight rubbing but that can be dealt with later.
I would recommend (18" rims) the 37x13.5x18 otherwise if you run the 36" they are 15.5 inches wide , on the smaller side there are 35x13.5 sizes also.
and all of the ATZ SLT tires are 3,500 load rating or higher so you still retain D-E classifications.
Friis
Herning, Denmark
Thanks, that was a supreme tip! I definately think, I will go with the 6"/37" solution. Anyway, allthough 8"/38" would be nice indeed, I don't want to run a truck that is too much in-your-face, because of local regulations.
Heres a foto of my stock SD and a very similar SD that has a 4,5" lift and 37" tires. I think it looks pretty good. 6" would be even better.GratisUpload.dk - Upload dine filer her
Thanks again. BTW do you know of any stores, that will ship the ICON/Donahoe kits abroad?
MidwestOffroad
MN
Also if you need to bring it back to the states it will need to fit in a container. so your limited there.
that picture looks bigger than 4.5
I am sure Ryan at SDHQoffroad.com or offroadwarehouse.com or Dave at Diablo Offroad.com or Jesse at farmboyfabrications.com will .
MidwestOffroad
MN
Friis
Herning, Denmark
Friis
Herning, Denmark
Wow, I downloaded your profile picture from Icons gallery before I knew it was your truck... That is a sweet ride indeed. I like the hood. Thanks for the advice.
Brad1103
