Superchips 1750 Micro Max Tuner
Ezzie
Erin, ON
I am looking to pick up an OBDII code reader for doing diagnostics and reset the MEL on my 2006 PSD (6.0 ltr.) F350 SD. It would also be noce to have a tool that could be used to check some performance parameters as well.
The documentation on this tuner is unclear if it will support the 6.0 engine codes (looks like it was designed for the 7.3 ltr.) and I hear that it is now obsolete and may not be updateable. Does anyone have any info on whether this will work or a recommendation on something else I should look at instead?
scottu5
