Stripped oil pan bolt
79jasper
El Paso, TX
Looks like 11's and early 12's had the plastic plug and oil pan.
Sent from my SM-G892A using Tapatalk
Tracy Mangus
Colorado
I saw a similar discussion on a different site about the oil plug, the ones they got from ford was tight in and out to replace and did not fit well, got a non oem replacement from a parts store and it screws in and out fine, Just if you want to check that.. may not be the Pan
jsum24
FL.
When I got the pan replaced, I also added the FUMOTO drain valve...............
Jriltex
