Help Needed Stipped out internal threads on hfcm drain plug
guyash01
nc
i have removed part of the hfcm housing but the side plat that the fuel lines connect to is still connected and that is where the threads are stripped out, how do you disconnect fuel lines from the side plate or is the another fix.:dunno
NJKen
Is a proud new daddy
central NJ
Im not quite sure im following you but if you only need to remove the fuel lines there is a tool for that. The one I use is made by AST. They are not the only ones that make it so you may have luck at an auto parts store. Basically it is an aluminum tool that goes over the steel line and slides inside of the quick connector to disengage the spring. It is called a Ford fuel line disconnect tool. Do NOT try to use a plastic version of this tool. They are made for garter spring connectors like the ones found on the AC system. They will get stuck in the fuel line connector and destroy the tool and the line.
Ken
scottu5
