Kay-Ja
This is my first post so pleased be gentle. Today was about 5 degrees F, I had the truck plugged in at work all day. Truck started fine I got 10 minutes into the drive home started shuddering and loss of power which led to the truck stalling out. Waited a few minutes and attempted to start the truck. It took three attempts to get it running. Drove the truck the other 30 minutes home with no power. When I was home shut it down popped the hood checked fluids and for loose connections everything was fine. I backed out of garage stalled in the road 25 feet from driveway again no power. Started the truck again hard starting and went down the road to stearlership to ask some questions. Same ride down to stearlership no power, just enough power to get out of its own way. Waste of time there no help. The one and only diesel mechanic was at a doctors appointment and apparently no one else in the shop knows anything about diesels. I started up the truck to leave and everything drove normal back to the house. Power was back and drove fine. The truck is 03 6.0 CC SB 4WD with no mods. Any advice or suggestions would be appreciated.
