f100cleveland
When In Doubt,THROTTLE ON
I have a right rear brake that hangs up so bad that it heated up rotor and wheel so hot you couldn't touch them after a 20 mile drive. It drags you to a stop if you try to roll to a stop. A few weeks ago I noticed that it would pull to the left when you first stepped on the brake after a drive. Took the wheel off and could pry the caliper loose easily.
when I step on brakes without motor running it seems to release but if I do it with the motor running it stays hung up. Planned on using it tomorrow to tow with.
